FeatureScript: Get extruded loop/face
Hello,
I'm working on a script that exports all the features in a model and saves them as a sequence of Sketch (defined by edges and constraints) and Extrude operations for down-stream processing in another application. The data structure should be similar to this ER diagram.
I use /api/partstudios/d/did/w/wid/e/features to get all features and I can extract the sketches with their edges and constraints just fine. The edges all have entityIds and the constraints make use of these entity IDs.
However when I now want to get the loop that is extruded by an Extrude operation I get this entitiy reference:
        "type" : 148,
        "typeName" : "BTMParameterQueryList",
        "message" : {
          "queries" : [ {
            "type" : 138,
            "typeName" : "BTMIndividualQuery",
            "message" : {
              "geometryIds" : [ "JGC" ],
              "hasUserCode" : false,
              "nodeId" : "Fw7bheyuFAclyzY"
          "parameterId" : "entities",
          "nodeId" : "YwtNXy9HOwP0MsqL"
How do I find which edges or sketch make up the loop "JGC"?
Thanks for any advice!
