Getting sketches 3 characters geometryIds through API
guillauem_d
Member Posts: 20 ✭✭
Hello !
I'm trying to create circular holes on my part using the API.
To do this, i first created the sketch then the extrusion manually and analyzed extrusion .json using feature list :
I'm guessing "geometryIds": ["JRC"] is the id of the sketch that is being extruded.
Now i'd like to do this programmatically but i don't know how to find the sketch geometryIds, the only thing I find when creating a circular sketch through the API is '"entityId" : "jpUy8ZpUH4Uy", I tried using this as a geometryIds but it doesn't work.
How am I suppoed to find this the sketches 3 characters geometryIds ?
Thank you in advance !
"type": 148,
"typeName": "BTMParameterQueryList",
"message": {
"queries": [
"type": 138,
"typeName": "BTMIndividualQuery",
"message": {
"geometryIds": ["JRC"],
"hasUserCode": false,
"nodeId": "F5vRpYBhnhF3bwB"
"parameterId": "entities",
"nodeId": "e/OW31rYeHDO6RYo"
There's a couple options.
You could do it differently and just make a query for your sketch and pass that into the extrude feature without needing to know the geometry IDs. It's not super well documented on how to do that.
Or you could get the geometry IDs and mimic how Onshape does it.
You'll need to use the evaluateFeaturescript endpoint to run some featurescript in order to get the query and then the transient Id of the faces and edge.
But the more important question, why are you using the API to put holes in a part. That sounds like something better suited for featurescript. Featurescript is great at modifying geometry.www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications0 -
thank you for your answer
I could learn featurescript, but I need to execute the command remotely trough API calls, and if i'm not mistaken, I can't execute featurescript through API calls ?
For instance, I learned how to make a simple extruded square :
FeatureScript 1821;import(path : "onshape/std/geometry.fs", version : "1821.0");annotation { "Feature Type Name" : "My Feature", "Feature Type Description" : "" }export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)precondition{// Define the parameters of the feature typeannotation { "Name" : "Length","UIHint" : [UIHint.SHOW_LABEL, UIHint.REMEMBER_PREVIOUS_VALUE],"Description" : "Set the length of the solid" }isLength(definition.length, NONNEGATIVE_LENGTH_BOUNDS);}{// Define the function's actionvar length = definition.length;// Create a new sketch on the Top planevar sketch1 = newSketch(context, id + "sketch1", {"sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)});// Draw a rectangle in the sketchskRectangle(sketch1, "rectangle1", {"firstCorner" : vector(-length / 2, -length / 2),"secondCorner" : vector(length / 2, length / 2)});// Solve the sketchskSolve(sketch1);// Extrude the sketch to create a cubeopExtrude(context, id + "extrude1", {"entities" : qSketchRegion(id + "sketch1", true),"direction" : evOwnerSketchPlane(context, { "entity" : qSketchRegion(id + "sketch1") }).normal,"endBound" : BoundingType.BLIND,"endDepth" : length});});
This works fine, but it's not possible to execute thise through an API call right ? I tried pasting the code through a POST /partstudios/d/{did}/{wvm}/{wvmid}/e/{eid}/featurescript but that doesn't work0 -
You can call arbitrary featurescript code with the /featurescript endpoint, but that cannot change the context or add a feature to the tree.
Its only used for getting information out of a part studio.
To modify a part studio with the api you need to add a feature to the feature tree.
https://cad.onshape.com/glassworks/explorer/#/PartStudio/addPartStudioFeature
This can either be a custom feature or an onshape built in feature.
But in this case the feature needs to exist in a feature studio in Onshape.www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications1
