REST API - Exporting a part to STEP works, but exporting to DXF does not
I'm trying to export my sheet metal part using the REST API, exporting it to a STEP file works fine using the following method :
- Initiate the exporting procedure using /api/v6/assemblies/d/{}/w/{}/e/{}/translations and inputing STEP as formatName
- Wait for the /api/v8/translations/{requestId} requestState to be DONE
- Download the STEP using /api/v8/translations/{requestId}
Where should i plug the face ID ? Here is my working code for STEP files :
I managed to get it to work, directly message me if help is required.
You cannot just list all parts and try to export them, non-sheet-metal parts will return 4xx. You need to identify flat patterns specifically using the insertables endpoint with includeFlattenedBodies=true:
Use deterministicId (from insertables), not partId (from the parts list). Export endpoints are keyed on deterministicId.
For the actual export step, use the official translations API (POST /api/v6/partstudios/d/{did}/w/{wid}/e/{eid}/translations with formatName: "DXF"). It's async — fire the job, poll /api/v6/translations/{jobId} until requestState === "DONE", then fetch the blob from resultExternalDataIds[0].
