DXF File Not Visible in Bambulab Slicer After Onshape Assembly
Hi everyone,
I'm a complete beginner when it comes to design. I recently bought a 3D printer (Bambulab A1 Mini) and wanted to print a shopping cart token:
https://cad.onshape.com/documents/ea9ac99d544f2728feef73f3/w/7aaf59238f4059603d374121/e/b5a33e24ba92328d40ebfa96?renderMode=0&rightPanel=appearancePanel&uiState=66ba7258bd1e7f28c9efd174
I created the shape in one Part Studio and imported a DXF file in another, then transformed (scaled down) it. In an Assembly Studio, I wanted to put them together and export the result.
It looks like it should work in Onshape, but when I import it into the Bambulab Slicer, the DXF file isn't visible.
Can you help me with this? It's probably something very simple.
Thank you so much and best regards,
Nick
  • Shouldn't it be exported as an stl file?
  • I've tried both. STL and 3MF
  • Your part exports and imports (into Cura) fine on my end. Are you trying to engrave text into the part? Looks like you've already figured it out?
  • I've now used a workaround and exported both parts separately.
    But I would nevertheless like to know if I did something wrong—maybe my mate connectors are incorrect.
  • @nick_loewecke
      I could be wrong, as I have little hands-on experience with a 3D printer, but I have some thoughts.
      In exploring your assembly, I never saw a time when you had the little vehicle sitting on the face; either it was set flush or spaced away a bit (I might have missed something). Does the slicer ignore parts contained within another part or not touching?
      Also, your vehicle is only extruded to a depth of .015mm. Is your printer even capable of that? Is there a setting in the slicer that tells it to ignore that fine of detail?
