How to achieve a Sheet Metal bend with interior unbent tab?
jason_kleban
Member Posts: 2 ✭✭
in Drawings
I'm trying to create this flat support that is not bent inside a bend. I get the visual effect, but breaks the part in two and the sheet metal drawing "cannot be resolved." Even thought the sketch has lines that can break up the face, I can't seem to select less than the entire planar face of the sheet metal model to bend.
I tried other stuff like unioning the parts and extrude-removing the interior relief cut, but no improvements.
https://cad.onshape.com/documents/fab008a0e9d313f824d72e7f/w/3ed034549eefde86d2d22811/e/fc39c8ded4e8c4fa42d68e96?renderMode=0&uiState=66bc96a5b7561231e9cbad6a
Twitter: @BryanLAGdesign
- Generate the base part, but without that cutout section
- Use boolean to remove the cutout section in bent form (make sure you cut all the way back to the flat face section)
- Use tab to generate that tab
https://cad.onshape.com/documents/198dba6be834e9b022244790/w/e7ce761895817e7dd6d2f828/e/985c837d49715f21ad3aa0d0
(Its not perfect but you get the idea)
Custom FeatureScript and Onshape Integrated Applications
