FS calculating plane normal
graham_lock
Member Posts: 277 PRO
Hi,
I'm creating a plane at an offset from a reference plane which I also want to angle at a given number of degrees.
My test code looks like this:
How should I go about generating the normal vector to achieve the desired angle?
Thank you.
const p is Plane = plane(
offsetDirection ? (refPlane.origin - (offset * refPlane.normal)) : (refPlane.origin + (offset * refPlane.normal)),
vector(0, 0.1, 0.3)
opPlane(context, id + "plane1", {
"plane" : p
Thank you.
FeatureScript transforms are great, they do a lot of heavy lifting for you.
If you create a rotation transform:var rotationangle = rotationAround(X_AXIS, 30*degree); var newVector = rotationangle*oldvector;
The one thing is that it only works with vectors that have a length.
So you'll need to take your normal, give it units (ie oldvector*meter), rotate it, and then remove units (newVector/meter)
www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications0
Experts in Onshape Automation - Custom Features and Integrated Applications0 -
Thank you.0
