having some trouble with opChampfer
I tried adding an opChampfer to my script.
But for some reason, it showed me an Error regarding the ChamferType:
The only way to "fix" this was to delete the chamferType-line entirely.
But now it will create only chamfers with equal offsets, even when I add the angel to the map.
Did I miss anything?
https://cad.onshape.com/documents/18bc9429cf74f25bda45bcb3/w/0a904f6ed90ecee8ff26b88f/e/265b505d5756f251893ce08e
Thanks in advance
Philipp
ChamferTypeis defined inchamfertype.gen.fs, which you'd need to import.export import(path : "onshape/std/chamfertype.gen.fs", version : "2411.0");1
ChamferTypeis defined inchamfertype.gen.fs, which you'd need to import.export import(path : "onshape/std/chamfertype.gen.fs", version : "2411.0");1 -
Thanks @_anton,
Thank you for the quick answer.
I almost expected something like this and I had searched the documentation for an import I might need but hadn‘t found anything.To avoid this type of issue in the future, where do I find what to import to use certain features?
Thanks
Philipp0 -
Good question. I go to the FS standard library (https://cad.onshape.com/documents/12312312345abcabcabcdeff) and find a tab I'd expect to have the right import (
chamfer.fsin this case). Then I see how it gets the import.0 -
Well, seems quite complicated, but at least I now know where to look.
Thank you.0
