Double-triangle sweep
AreoResearchAreoResearch Member Posts: 2
Hi,
Ive been lately trying to make frame model, but the sweep tool dont work if you select more than 2 lines emerging from one point, any solution? Is there better way to do this?
Thanks for the answers,
VM
  • S1monS1mon Member Posts: 4,077 PRO
    edited August 2024
    Try using the frame tools.
    https://www.onshape.com/en/features/frames
  • rick_randallrick_randall Member Posts: 417 ✭✭✭
    Like S1mon said, Use the "frame" command - but you might not be able to select all paths at once, you may have to make multiple frames to do the job. In addition, selection order matters - so that miters end up looking the way you want (little bit of trial and error here). There is a learning curve, but in the long run, it's still probably the best way to get what you want. Hope this helps
