How to fit a surface through this?
viamarkable
Member Posts: 10 EDU
I have a set of curves that I want to fit a surface through. However, there seems to be too many guiding curves and I can't figure out how to create one surface through this. Loft/Sweep don't seem to be working, any advice how to make such a surface or approach this issue?
The attached images are the curves that I have and the two smaller rounded surfaces are the start/end points (defined by the curve). For extra reference, if needed, I'm trying to replicate/CAD a duplicate of my apple earpods and the part in question right now is the main body of that. Here's the link to the document: https://cad.onshape.com/documents/3ad308dcd5281cdbb98f921e/w/d5d6d7f79110a5fe14127672/e/9f3315b6613bf8ef041ff035?renderMode=0&uiState=66c0f1e6a01a1d79edae7f63
All pictured curves are from Sketches 5, 10, 11, 13, 14, 15, 16, 17, 20, 22, 23, 24, 25, 26
Thanks for all the help!
