Can't Undo Unpacking a Folder
Jonathan_Hutchinson
Member Posts: 152 PRO
A very minor thing, but I found I couldn't restore a workspace to before unpacking a Folder, which I did by accident. It says that my Main is already up to date with before the unpacking, and so the option to Restore doesn't glow.
3
Definitely something that should be in the edit history. I reckon it's worth an improvement request
The peculiar thing is, it shows in the edit history that you did the unpacking of the folder. But when you roll back to before it, you can't restore. I think this is probably a slight bug caused by the new method of restoring mimicking versioning/merging, whereby it's done on a tab by tab basis.
