Epoxy/Glue Joint
sirllama
Member Posts: 4 EDU
Hello, I am cading a boat hull and in order to print it I need to split it into multiple pieces. I want to have the hull be thicker where it connects to each other as well as have a grove on one part and then a ridge that goes into it to help with alignment and more surface area for the glue. If anyone could help find a feature script or show me an easy way to do this it would be appreciated.
In the above picture the boat is split into two pieces (the back left and back right pieces)
