Loft and Guidelines
savi_garcia
Member Posts: 8 ✭
Consider This Document:
I am new to OnShape form Youtube (I usually use Freecad) . Onshape seems to have a better curve handling system. So let's make a very complicated submarine thing to test it out.
I want to loft Sketch 4 to Sketch 5, But on one side, I need to apply a guide, which is Sketch 6. But adding this as guide makes the error output:
Loft 3 did not regenerate properly, Could not add internal Vertices, Split profiles at desired points.
I have removed all conditions on the ends. But nothing works.
Question: how Do I deal with this?
I would like a step by step explanation please.
