Possible to restrict configuration list combinations when using multiple lists
william_lacey140
Member Posts: 19 ✭
I have a model of a frame that I'm looking to make that is available in standard sizes. I have about 6 different widths that are specified in a configuration list input, and about 9 or 10 heights that are specified in another configuration input. I can select each with and each height independently and adjust the model, but certain combinations are not standard and I would like to ignore them.
As an example,
Widths available:
300mm, 500mm, 750mm, 1000mm, 1250mm and 1500mm.
Heights available:
500mm, 750mm, 1000,mm, 1250mm, 1500mm, 2000mm, 2400mm, 2500mm, and 3000mm
300mm width is available in all heights except 3000mm.
500mm width is available in all heights.
750mm width is available in all heights starting at 750mm tall.
1000mm width is available in all heights starting at 1000mm tall.
And the list goes on, but you get the idea. Is there a way to restrict certain combinations while still allowing the user to select each variable and restrict the choices based on what they pick?
I had the same question - the short answer is no. The long answer is kind of.
I've got an improvement request for this here if you'd like to vote it up:
And there are some suggestions on workarounds here:
