Face blend troubles
jur_delmeejur_delmee Member Posts: 3 EDU
so, ive got this shape, but im trying to faceblend both parts together in the same way i did with all the spheres within each part
but its giving an error because sphere next to it,
it does get fixed when i 'detache' the thing, but that results in a 'surface' which i dont want
any1 know how to fix this?
  • S1monS1mon Member Posts: 3,959 PRO
    If the end result you want is the 5 spheres but with face blends between all of them, you might consider modeling the spheres so that they intersect by a microscopic amount to begin with. Then you could just use a regular fillet instead of face blends.
    Here's a document where I created a sphere, patterned it so that the spheres just barely intersect, and added fillets to all the intersections using the Selection Fillet custom feature. There's probably an even better way to pattern the spheres so that all of your parts could be done with one part studio and configurations.
