How to dimension on an extrude?
w_s856w_s856 Member Posts: 58
Context: https://cad.onshape.com/documents/d7aebcbf751ea63aa06fa480/w/d496255ea19f9425bb0ebe6c/e/1fe3d10623afa6ca25027db7?renderMode=0&uiState=66d57fb617ff872f8c5b10a3
I have a ring with a gap. I want this gap to be a certain size.
The ring is done as a sweep of a circle on a circular path.
I measured the size of the gap on the center of the circle to be swept, but since the cut will be perpendicular to the path and the ring has a width, the effective size of the gap is smaller
Is there a way to set the dimension on the final object (and not on the sketch)? Or should I do the math myself? Or is there a standard way to address such cases?
I will probably end the gap with a fillet - which could even more complicate the situation→ I think there is a better way to manage such gaps (?)
  • robert_scott_jr_robert_scott_jr_ Member Posts: 730 ✭✭✭
    If not in the sketch you could create another solid at the intended gap and do a Boolean Remove to create the gap. However, perhaps what might be better is to have sketch 2's circle's circumference rather than the center intersect the path for the sweep. - Scotty
    kasia-holder - Copy | Part Studio 2 (onshape.com)
  • w_s856w_s856 Member Posts: 58
    I am not sure I understand this. I created the gap by removing a piece of a circle (the path).
    Do you mean that I should / could have created a posteriori another solid embedded in the (now full) circle and subtract it? I imagine how I can do that but I am not sure how it would help with the size of the gap.
    This is brilliant, thanks! I never looked at mate connectors because I did not yet need to do an assembly - but I see that they have other issues as well. I am unsure how this differs from a plane, but I will read about mate connectors and ask a new question if needed.
    Thanks a lot, also for the corrected drawing which helped me to exactly understand what you meant.
  • glen_dewsburyglen_dewsbury Member Posts: 1,252 PRO
    Here is another thought building gap in sketch with variables.
    https://cad.onshape.com/documents/fa40a8e0adf37af8a2dd7498/w/91a671687060dc5bdeb87877/e/31a34f84bd2d35893363653b
    Yes. Check the linked document again. (Use the roll back bar to follow the new features) - Scotty
