Samples demonstrating how to create some basic, common shapes?
neobobkrauseneobobkrause Member Posts: 105 EDU
i understand how to create a sphere. But what about one defined via variable values such that I can control its X, Y, and Z dimensions? A similarly configurable torus, a trapezoid, etc...
Thanks for for any help. I'm obviously new.
- Bob
  • henry_feldmanhenry_feldman Member Posts: 131 EDU
    Do you mean how do you use variables to change constraints/dimensions inside a sketch used to generate 3D features via loft/revolve/sweep?
  • neobobkrauseneobobkrause Member Posts: 105 EDU
    Yes. I basically want to build up a library of generic yet configurable shapes like the ones I've mentioned that I can bring into any designs that call for them. Properly designed, I can treat each shape as a "black box". I can (almost) forget how the shape was constructed. In software this is called encapsulation. -- Users only need to know the interface, not the implementation.
    Doable in OnShape?
    - Bob
  • michał_1michał_1 Member, Developers Posts: 215 ✭✭✭
    I think it's possible, but pointless. In Onshape we can have derived parts within same document only. You can have a custom library of parts, but for now there's no way to place them in other document.
    Ouch. It's early.
  • Darren_A_HenryDarren_A_Henry Onshape Employees Posts: 68 image
    You can cut and paste part studios between documents.  It creates a true copy without associativity.  Simply RMB Click on the tab and copy to the clipboard, then open the new document and use the + menu to paste the tab.
    Boom! That's all I'd need then. We're back in business.
    So... Are there any pubic or tutorial drawings with these commonly used shapes?  I come from the Tinkercad world where these shapes are as common as ants on a banana peel.
    I'm so happy to be wrong. Recently I was in need to re-create one of my designs in new doc, and I was about to do it step by step... Darren you've saved my life. (Bob forgive me slight off topic).
