Maximize Properties window
Severin_123
Member Posts: 47 PRO
in General
In my opinion, the window to enter Properties should be the same size as the "Create Release candidate" window. Or there should be at least the option to maximize the windows. In industrial use there are way more Properties to oversee than the 5 Properties you can see in the current Properties window. With a bigger window and maybe a 2 or 3 column view this could be better to work with.
1
