FS Frame
graham_lock
Member Posts: 277 PRO
Hi all,
Is there a recommended way of creating frames from within Featurescript?
I note there isn't an opFrame?
Thank you.
Here is an example of how to do this: Custom Frame Feature
Currently, you have to import the frame feature in order to do this. See line 3.
FeatureScript 2455; import(path : "onshape/std/common.fs", version : "2455.0"); import(path : "12312312345abcabcabcdeff/6105196984064c2818b6eea9/7d39eff85eff86d560b39fd0", version : "250ae03e4007e9684f18a5ba"); annotation { "Feature Type Name" : "Frame test", "Feature Type Description" : "" } export const frameTest = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Library Definition" : "65dcc2a02c4ff1c239467ec9", // This is the id of the Onshape Frame Profile Library definition "Name" : "Sketch profile", "Filter" : PartStudioItemType.SKETCH, "MaxNumberOfPicks" : 1, "UIHint" : UIHint.REMEMBER_PREVIOUS_VALUE } definition.frameProfile is PartStudioData; annotation { "Name" : "Edges", "Filter" : EntityType.EDGE } definition.edges is Query; } { frame(context, id + "frame", { "profileSketch" : definition.frameProfile, "selections" : definition.edges, //"angle" : definition.angle, //"angleReference" : definition.angleReference, //"defaultCornerType": FrameCornerType.MITER, "defaultButtFlip": false, //"index" : definition.index, //"trim" : true, "trimPlanes" : definition.trimPlanes, "trimBodies" : qNothing() }); const frames = qCreatedBy(id + "frame", EntityType.BODY); setProperty(context, { "entities" : frames, "propertyType" : PropertyType.APPEARANCE, "value" : color(1, 1, 1) }); });
▚▞▚▞▚▞▚▞▚0
▚▞▚▞▚▞▚▞▚0 -
Thank you.
