clock face circular pattern
charles_arnold
Member Posts: 6 ✭
I am trying to create a clock face with the hour numbers. I have done the following:
- create variable in the feature list: count as number = 0
- create a second variable in the feature list: count as number = #count + 1
- create a sketch. draw text using the expression: toString(#count)
- extrude the text
- create a circular feature pattern:
- instance count: 12
- angle: 360 deg
- features to pattern:
- sketch
- #count
- extrude
- reapply features is ticked
The pattern creates 12 numbers but they are 1's. The text does not update with each instance!
Any thoughts will be gratefully received.
Try this:
@S1mon - that is absolutely brilliant. Just what I was looking for.
