Can I use variables for Textfonts
udo_besenreutherudo_besenreuther Member Posts: 2
edited September 2024 in General
Is it possible to define and change the text font in the surface text tool using a variable?
I have a project in which I place many individual letters (128) on a surface using the surface text tool. I would like to be able to define the text font using a variable so that I can quickly create different variants of this part.
I have not yet found a way to select all surface text elements and then change the font for all elements; that would also be a solution.
Greetings Udo
  • rafael_telgmannrafael_telgmann Member Posts: 138 ✭✭✭
    Hi, the only option I see is to use configuration. This is not exactly what you asked for, but may be helpful.
