STEP BY STEP SHEET METAL
marcos_fenerichimarcos_fenerichi Member Posts: 5 EDU
Does anybody know how or if we can create a variation of a sheet metal folded profile?
take a look at the example below. The first step is the flatten and its okay. Following we have the first fold process and so on.
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    Hey @marcos_fenerichi,
    You could design your finished profile and the use configurations to suppress each consecutive step and show the previous steps.
    Hope this helps. Cheers
  • marcos_fenerichimarcos_fenerichi Member Posts: 5 EDU
    Thanks for help. I haven't done the unfolding steps yet because I don't quite understand how to use the configurations yet. I try to create the finished profile with angular dimensions to variate the steps. However, I hope in the future OnShape creates an unfold and fold option like other software do.
    @marcos_fenerichi
    Are you designing this part from scratch in Onshape or in reverse starting from the flat pattern with a DXF? Thanks
    Starting from stratch. I desgin the profile then I create the steps ( configurations)
  • robert_johnstonrobert_johnston Member Posts: 62 PRO
    Are you wanting to show the steps just from a drawings perspective to show the bend sequences?
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,060 PRO
    Why do you need to show the bending sequence? I've never had a vendor ask me for that.
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 980 ✭✭✭✭✭
    edited August 2025
    Bryan Lagrange
    Twitter: @BryanLAGdesign
    edited August 2025
    Bryan Lagrange
    You could also export the flat pattern of your finished part as DXF. Create a new Part Studio, insert the DXF in a sketch, Sheet metal THICKEN and then use the bend feature to recreate it again, step by step. Sounds a bit tedious though as you are essentially doing the work twice.
    What is your use case here?
    In some regions of Brazil, we have a huge shortage of machinery, processes, and labor. Some companies operate in a very simple manner, and a student highlighted this need, as in his company, all sheet metal process drawings are created this way, not simply the sheet metal blank. In Solidworks and Autodesk Inventor, this type of process can be easily created with the help of bending and unfolding tools, and I'm trying to replicate it in Onshape. This would give us another user of the software. However, I will try to create configurations with varying angles. As soon as I complete the example, I'll send it to you.
  • S1monS1mon Member Posts: 3,985 PRO
    There's a new third party SaaS CAD tool in development which can show folds step by step. It's aimed at packaging development, but it seems like it could work for many sheet metal models as well.
    https://packcad.com
    https://app.packcad.com/mockup/
