Cut from a drawing
Hi all
is there a way to cut a part from a whole CAD File and export it like in my printscreen?
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    edited September 2024
    Hey @pascal_marco_berlinger,
    No 100% sure what you need here but you can create a new sketch of the area you want to have, extrude with intersect selection or extrude that as a surface and use the surface with the Split tool to only end up with that little cut/slice of your part.
    Hope this helps. Let me know. Cheers
