BUG - Split command breaks derived MC
Ulises_FMUlises_FM Member Posts: 74 PRO
edited September 2024 in Product Feedback
I think I found a bug in the Split command (not necessarilly a bug but a consequence of how it is programmed, resulting in user incovenience).
When splitting a Part that has derived MCs, none of the splitted Parts keeps the derived Mate Connectors. This is due, I believe, to the fact that the split commands deletes the original derived Part and creates two new splitted Parts with some acquired properties (such as Part name), but does not keep the derived Mate Connectors from the original.
I made an example to illustrate this issue.
I have an original Part with two MC linked to it.
Then, I use the Derive command to create a Derived Part, bringing the MC along.
As it can be seen in the assembly, the MC associated with the Derived Part are kept.
However, when I use the Split command, the reference in the assembly is lost, and inserting the two newly created Parts doesnt bring any of the original MC with it.
This issue does not happen with boolean part operations, since you can choose which of the original Parts that are inserted into the boolean operation is kept.
I know it might but an issue hard to fix, since it is derived from the way the split command works. But, does anybody have a workaround to keep the original MCs?
  • jelte_steur_infojelte_steur_info Member Posts: 595 PRO
    Ugly, but it probably works. You could try a Transform "copy in place". split that copy, and use the result(s) as the tool in a subsequent boolean subtract.
  • Ulises_FMUlises_FM Member Posts: 74 PRO
    Thanks for the advice, that definitely works and it might be the best workaround!
