Pulling from other assemblies to make sheets in the same document?
jack_erhart
Member Posts: 140 ✭✭
I am orgainizing my models with decription sheets in a drawing.
I have created assemblies for each section of the model.
I would like to be able to create a series of sheets in one document, and be able to export that document out to one PDF with several different sheets of instruction.
Here is the document I created:
I have sheet #1 referencing the assembly named 101 Mainframe.
I would like sheet #2 to reference the assembly named 101 Suspension. And create a series of sheets in one document.
In the dropdown menu for reference, I am not seeing the other assembly name to insert parts from it.
Could someone instruct me on how I could achieve what I need to do?
Thank you..
Got it figured out folks! I needed to create the assembly within the document I wanted to insert it from, and choose Assembly choice not Part Studio. So my workflow needs to incorporate creating the assembly before I access it for inserting into a sheet.
Just FYI for anyone else.
Thank you.
