What is the proper way to model this?
in General
Look at this very basic model:
It is just a circular base shape, and it has two protruding arms. The arms are pointing upwards, and they are also pointing outwards from each other.
Assume that I want the top surfaces of these arms to be parallell, so that a plane surface would rest flat on both arms.
What is the best way to model something like this? The model shown here isn't correct, it just shows the basic shape I'm after. The easiest method I could find, was actually to create a plane just above the arms, and then use replace face to make the top surface of the arms parallell, but somehow that feels like cheating. I could of course create that plane first, and then sketch on it and extrude down, but that would make the attaching point to the base look slightly funny. I should add that in this example I only modeled one of the arms, and then mirrored it.
This is probably a painfully basic question for you experienced modellers out there, but for a novice it isn't immediately obvious how to best do this.
_Dave_
projektowanieproduktow.wordpress.com
https://cad.onshape.com/documents/4d3a3befc86f475c86e135ad/w/ea2bd8a23ebc4bdcbf2079cf/e/ef012749ae6d47fca116b6b6
https://cad.onshape.com/documents/61fd6dfb5b97417f8abeaf8d/w/f16f5e7e0a394ee6810d51eb/e/9a1dddfc791d440d8c6dc853
However, to acheive this, some geometry has to look weird, so to speak. If the intersection between the circular part and the arms looks good, and the top faces are coplanar, then the end faces of the arms will not be rectangular.
