Slanted sloping. How does it work?
frank_förster556
Member Posts: 4 ✭
Hello,
I have to model a slanted surface (sloping from top right to bottom left on the square part) on the linked workpiece, but unfortunately I don't know how to do it. Can someone please show me which tools to use?
Thank you in advance!
robert_scott_jr_
Member Posts: 841 ✭✭✭
Hello Frank. Here's one way. I suspect there may be a cleaner, simpler method. - Scotty
eric_pesty
Member, pcbaevp Posts: 2,786 PRO
You can do it simply using "move face" and picking mate connector for ref. Either using two move faces, or using a sketch to define the axis and one move face feature depending on how you want to control it:
Even just a single draft feature using a MC:
Handyhalterung B7_Test - Copy | Part Studio 1 (onshape.com)
Thank you very much, this is so simple, yet sooo good! I tried for several days without success!
Man, there's still a long way to go until I master the tool even a little.
https://cad.onshape.com/documents/131d5e59a1376150cc0ccda4/w/fa64480e543d631b52d0830a/e/51268909e1e4e7eaad7bbcd3?renderMode=0&tangentEdgeStyle=1&uiState=66e8c61ab5b2f027979d373c
https://cad.onshape.com/documents/131d5e59a1376150cc0ccda4/w/fa64480e543d631b52d0830a/e/0287e57db2ab593ee3e7566c?renderMode=0&tangentEdgeStyle=1&uiState=66e8c6d6b5b2f027979d37be
