29 August 2024 update : fillet outside edge loop not anymore possible
Lysandre_Aubourg
Member Posts: 2 ✭
Hello everyone,
The latest update provided some interesting feature, but it seems there is also some limitation on the fillet feature : a fillet cannot be done anymore if larger than the face it lies on.
Previously I was using the capacity to make fillet larger than one of its face to make jog, the small face being consumed.
Step 1 : make a straight jog using "move face" feature
Step 2 : make the inner fillet that consume the straight face
Step 3 : make the outer fillet to finish the jog.
Now since the update the step 2 is not working anymore :
I have to reduce the fillet radius to make the fillet works, but then with the thickness of the part it cause troubles.
Is there a way to fix this ?
