All my sketches are suddenly "not fully defined"
I'm actually totally stumped. Just this evening everything is fine then suddenly all the sketches I have shows the "is not fully defined" error. The model is not affected, its still there but I'm afraid that this might not export and 3d print the way it used to.
*** UPDATE ***
Ok, I figured it out as I'm writing this. The sketches have points that are not constrained but its using variables so if the variables are adjusted some of the points will not move according, If you encounter this, just check which point is not constrained and anchor it somewhere that the variables affect. Incidentally some points are actually save because the lines do follow other lines and points not being constrain is not an issue. If your 3d model has been deployed and printed once it won't be an issue. Nothing will be messed up.
