How to fillet an offset
So I have a board with letters. The recess for the letters is good but the letters' corners are not curved. I added the fillet to the main outline but when I added an offset (insert) the fillet didn't stay. I have attached screenshots of the plans. Any help in getting the inside corner to be filleted would be helpful.
Screenshot_20240920_210731_Onshape.jpg Screenshot_20240920_210831_Onshape.jpg
  • joshua_galloway530
    joshua_galloway530 Member Posts: 4 ✭
    I managed to solve it, I had to remake the outside line as the "full" shape, no rounded corners or anything like that, then do the inset, then do the fillet. Thanks everyone for your help!
  • Oliver_Couch
    Oliver_Couch Member Posts: 230 ✭✭✭
    If you offset an arc (fillet) inward then the radius will reduce - the corner gets sharper. That's maths, no way around it.
    Perhaps you could just offset the straight edges and then create new internal fillets of matching radius to the external ones.
  • robert_scott_jr_
    robert_scott_jr_ Member Posts: 939 ✭✭✭
    Joshua, you could apply fillets without doing them in the sketch. Just in case you are unaware, there is a fillet tool in the part studio. Would that be applicable to your needs? - Scotty
    S1mon Member Posts: 4,610 PRO
    For something like this I would make the recesses with the Boolean tool with Offsetting all surfaces. Then I would use the Selection Fillet custom feature to select all the inside edges which are similar.
    https://forum.onshape.com/discussion/13958/new-custom-feature-selection-fillet
