Errormsg: Sketch not fully defined
roger_m_kolaksroger_m_kolaks Member Posts: 30 ✭✭
I'm seeing this alert on two of the sketches in the linked document. Could someone help me interpret the errmsg so that I might make the necessary corrections?
I am also seeing unexpected lines when I import the exported DXF files into Mathematica. Might the two issues be related?
..rmk
https://cad.onshape.com/documents/c2b4bda4b88b048be7519e40/w/d255cbae9b54a9e5d46906f7/e/1df9d435d1e3464b2b8b53bf?renderMode=0&uiState=66ee22f0ef2dbc42af2c0154
  • glen_dewsburyglen_dewsbury Member Posts: 1,253 PRO
    This is a warning not an error. It means that there are entities not constrained that can be moved around in sketch 'vertices'. In sketch 'reducing edges' I simply added a fix constraint to the note and the message went away. Blue entities are unconstrained and black are fully constrained.
  • roger_m_kolaksroger_m_kolaks Member Posts: 30 ✭✭
    Thank you.
    In the Sketch "vertices" it appears that the 100+ vertices are unconstrained, at least my aged eyes detect a blue tint to them. I find this curious because all the elements are Mirrors of the initial octagon that I created with the Polygon tool.
    It also seems that few of the edges are shown as Coincident with their vertices. Perhaps this is the result of using a Projection of an earlier Sketch as a foundation.
    Is there a method I can use to delete all Projection constraints in the Sketch or would I have to select and delete each independently?
