Help using sweep to create an inverse fillet
Hello,
I'm having trouble creating an "inverse fillet". My goal is to recreate the bottom fillet on a box for the top edge so they can be stacked easily.
Here's my current drawing. Sweep works nicely when I select the circle for the form and a single edge. As soon as I try to follow the edge and select one of the corners, OnShape fails because the sweep intersects. Doing each edge in a separate sweep doesn't do what it's supposed to - supposedly because of the circles orientation in the sketch.
My next try would be to create a sketch for each fillet, but that seems excessive and I hope there's a better way. Looking forward to any tips!
Thanks,
Jan
Having the same fillet radius inside and out (10mm) does not give s good transition around the corners. The corner by that method causes a thickening at the mid point of filleted around the corner.
1
1 -
Hello Jan. How about stacking a couple and doing a Boolean Remove? - Scotty
You need to remove the part of the circle that will "turn back on itself" in the corners.
Just draw a vertical line in you path (aligned with the inner wall) and only sweep the part of the circle on the left of it:1 -
Thanks a lot, that helped.
