Decimal Places in BOM for Custom Properties
Is there a way to make this better?
Possible to round off to 2 decimal places? These are custom properties defined as double (I do need a number for agregation so I can see the total cost of an assembly for example)
it seems it might be an issue with the rounding function that maybe does not round properly?
Example here, first line seems ok but second line not:
Here is the function I'm using to calculate that parameter:
round(#cabinet_vol/(1e6 mm^3)-#LF_Displaced_Volume-#WA_Displaced_Volume-#HF_Displaced_Volume,0.1)
ok! I think I figured it out, I used RoundToPrecision instead of round…
But now I'm strugling with how to use RoundToPrecision in featurescript, it doesn't seem to work when I do this:
const weight = roundToPrecision(volume * definition.density, 2);
throws this error:
