Draw Circle and erase 3/4 of circle and extrude.
charles_harris178charles_harris178 Member Posts: 15 ✭✭
Hi
Absolute beginner still.
Need a tutorial, example online, or advice on how to remove 135 degrees of a circle 500mm radius. then with the 45 degrees left to extrude into a rectangle shape end on 32mmx 3mm . Then represents a curved flat bar.
Thanks
Charles
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 893 PRO
    If you took 135 degrees out of a circle, you'd have 225 left. Maybe you meen out of a semi-circle. Either way, I think you're looking for a Revolve.
