Triangular error icon in custom feature that is running correctly
Hey there,
I've written a custom feature to rename bodies. The feature is working as intended, but often (sadly, not always) when I change features above this feature in the feature, I get this icon:
The feature is still processing data correctly - the correct bodies are being assigned the correct names, the correct strings in body names are being replaced, etc. There are no notices Featurescript notices that give me an indication of what's going wrong.
The code for the feature is located here. As best I can tell, the feature 'thinks' some queries are incorrect (even though they're working correctly). I can clear the error out by triggering editing logic - so I'm willing to bet that the issue stems from there.
Any insight into this error and ways to resolve it would be hugely appreciated!
Thanks!
-j
My guess is that the query you assign in editing logic is not robust.
But I'm not able to replicate the error with your code.
What steps are you taking to cause this?www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications1 -
Hey Caden,
I get this error when I use a new .csv import file for a new design/size. I'll share a document with you that's configured. You can trigger the error by switching the configuration (which in turn starts with a new size/csv file).
Thanks!
1
