How to progressively scale (feature pattern)?
Chris_Petersen
Chris_Petersen Member Posts: 8 ✭✭
I'm trying to find a way to pattern a feature along a curve, with each instance getting progressively smaller. I have this mostly working now in https://cad.onshape.com/documents/3f3ec37e1e353bb9998bd4df/w/b34f22505171e049af84230b/e/5c18dc15b37a5a597c65597d but the act of scaling also seems to be applied to each element being positioned on the curve, such that the X/Y/Z positions along the curve are all shortened by the same amount as the object's scale:
This is easier to see this is the root cause of the issue when the transform is changed to only affect the Z axis:
But of course, this isn't helpful when I need the transform to be uniform and/or the curve extends in multiple dimensions:
Does anyone know of a way to do this, or a published featurescript that isn't subject to the same scaling … feature?
