Linear pattern not extruding on all parts
Hey Folks,
Im having a small issue working on a design and think I'm again missing something ovbious. Im recreating a part I created super fast in tinkercad and am struggling in onshape. Overall width should be 55mm and length should be 335mm with the 4 central plates extending over the edges. Theres 23 holes in each horizontal bar, and should be 37 bars in total. the rest of the dimensions are not massivly important.
I created this with a sketch and extrusion creating the the 4 long plates on the bottom, then a sketch designing the horizontal bars and finally a sketch with a linear pattern for boring the holes through everything. So far so good.
Now when creating a linear pattern of the bars with the holes in they are ot going through the long plates on the bottom even though they are doing so on the original.
Im not sure what is wrong, but can only assume its because my initial sketch is underdefined, but I'm not sure how much more definition it needs as all measurements are defined
https://cad.onshape.com/documents/816278c1aea087330ff39d4c/w/568302bdcf722c0a15337d3e/e/b7f795b1768ed22be2350375?renderMode=0&uiState=66faa240eebf9065d35020e8Error
If anyone would be willing to explain what I've done wrong that would be great for defining my knowledge.
