Continuous Line+arc sketch, curved-linear pattern
Hey there.
I've got a sketch of two circles and two tangent lines.
Then I've got a piece (the blue one) that I want to repeat x times, following the exterior path that the circles+lines create. As the sketch is made up of different shapes and lines, I cannot make the blue piece to follow the exterior path,
I believe that a solution would be using the linear pattern tool with the piece for every line, right?
I found this guy with the same problem, but still no solution:
(btw, I am quite new to this, so sorry if I seem stupid)
curve pattern will get what you're looking for.
https://cad.onshape.com/documents/fcf16a7b426baf96cdb7035b/w/8b383ea3a3b0b03a7a3e70e7/e/bcb3dadc6087fe985890d380
That did solve the problem. Thanks a lot!
