Making a nice image with onshape
wout_ververswout_ververs Member Posts: 2
Hi all,
I would like to make a nice image of an object that I have created in onshape, I want to use the image for my thesis cover. The printing company suggests a .tiff or a .eps file for the image. Do you have any suggestions what route to take to obtain the best result?
Thank you in advance.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 367 image
    The easiest way is using the Print function located in the menu next to the Onshape logo top left of screen. You can choose a variety of sizes (up to A0 which will give a 14030 x 9923 pixel image!) and will create a PNG file with no background (alpha transparent). This should be pretty good. Make sure you choose the desired rendering mode (shaded, edges on/off, tangent edges on/phantom/off, etc) then press Download image.
    Of course if you have access to Render Studio then you could always use that… but I suspect for a thesis cover the Print option will be what you need.
