Is there a way to "restore" the BOM sort order?
eric_pestyeric_pesty Member, pcbaevp Posts: 2,635 PRO
By default the BOM items are sorted based on the assembly structure. You can override it by clicking on a column header (so far so good…).
However I can't see a way to revert back to the original order after doing that… Am I missing something?
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,094 PRO
    Keep clicking on the column header. It will go ascending, then decending, and then back to the tree order,
