opBoolean subtraction parameters
graham_lock
graham_lock Member Posts: 277 PRO
Hi,
I have the following inputs:
annotation { "Name" : "Start Former", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 1 }
definition.startFormer is Query;
    annotation { "Name" : "End Former", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 1 }
    definition.endFormer is Query;
I set local consts for those queries:
const startFormer = definition.startFormer;
const endFormer = definition.endFormer;
I create sketches on faces of the above parts.
I then create a loft between the sketch elements created on those faces.
opLoft(context, id + "loft1", {
"profileSubqueries" : [ qSketchRegion(id + "sketchStartFormer"), qSketchRegion(id + "sketchEndFormer") ],
I then want to cut the lofted part into the startFormer and endFormer parts.
I'm having problems with the cut, I've been trying variations of:
opBoolean(context, id + "boolean1", {
"tools" : qCreatedBy(id + "loft1"),
"operationType" : BooleanOperationType.SUBTRACTION,
"targets" : qUnion(startFormer, endFormer),
"keepTools" : true
but I can't get past invalid input errors.
Any help appreciated.
Thank you.
