Cut List Decimal Precision
I have a Cut List on drawing and can't find a way to show les decimal places in the length column. I've tried changing the workspace units and this effects the Cut List in the Part Studio but not the one in the Drawing.
Replacing the Cut List with a new version doesn't help.
Does anyone have any thoughts?
Many thanks
MichaelPascoe
Member Posts: 2,775 PRO
You could use the Cut List+ feature. Per your post: I just added the option to round to precision. It also does some other nifty things like optionally adding the length and angles to the part name, etc…
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴3
I have an improvement request here
My workaround for now is to create the automatic cut list in the space off the drawing sheet, then copy it into a manually created table.
Thanks Oliver, I'll follow your workaround
https://cad.onshape.com/documents/3ef342976bcbf59ab1fab2a0/w/5f79cf18283f48b7f07279f9/e/7707d784b4c5…
Many thanks Michael that looks great I’ll check it out
@MichaelPascoe you're a hero.
PS. There's a typo in your UI - 'Percision' should be 'Precision' (e and the r are switched)
ty @Oliver_Couch! It has been corrected.
