How do I get the endpoints of a curve?
joshtargo
joshtargo Member Posts: 657 EDU
edited October 2024 in FeatureScript
I want to have point1 and point2 default to the endpoints of the already selected curve. but if someone picks new points explicitly, it will use those chosen points.
I am editing a fork of transformCopy.fs
    annotation { "Name" : "Entities to transform or copy",
                 "Filter" : (EntityType.BODY || (BodyType.MATE_CONNECTOR && InContextObject.NO)) && AllowMeshGeometry.YES && SketchObject.NO,
                 "UIHint" : UIHint.PREVENT_CREATING_NEW_MATE_CONNECTORS }
    definition.entities is Query;
later:……
const endpoints = evaluateQuery(context, definition.scaleEndpoints); // Calculate the chord vector from the two selected points const point1 = evVertexPoint(context, { "vertex" : endpoints[0] }); const point2 = evVertexPoint(context, { "vertex" : endpoints[1] });
  • Caden_Armstrong
    Caden_Armstrong Member Posts: 464 PRO
    Since you are already creating code that takes in two vertices, you could find them from an edge using
    qAdjacent(yourEdgeQuery, AdjacencyType.VERTEX, EntityType.VERTEX);
    An edge will always have only 2 adjacent vertices that are its endpoint.
  • Jacob_Corder
    Jacob_Corder Member Posts: 141 PRO
    also evEdgeTangentLines with parameters [0,1] will give you the points at the end. the array is of lines so it is startPoint = tl[0].origin. endPoint = tl[1].origin
