Evenly space holes on a face following two sweeps.
mttr_mttr402mttr_mttr402 Member Posts: 9
This is a section view (upper image) of what is required but I just can't figure how to implement it. There are two sweeps that follow the yellow pattern. I need holes at regular intervals on the outside Left face that penetrated the outer and inner sweep. The purpose is that a pin will go into both but is removable, but will prevent the inner part from falling out of place.
  • S1monS1mon Member Posts: 4,052 PRO
    What sort of “regular intervals“? You can make a curve driven pattern of the holes.
    https://cad.onshape.com/help/Content/curvepattern.htm
