Animating the second stage of a geartrain
james_aguilar160james_aguilar160 Member Posts: 57 ✭✭
edited October 2024 in Using Onshape
Hi, I'm making a two-stage planetary gearbox. In real life this thing works as expected but I'm a little stumped on getting it to animate as expected!
https://cad.onshape.com/documents/696ed47dd6e84f881da8c56c/w/a7db5e51e522e9ce3267da1e/e/af4efb9a20716f279ac14f39?renderMode=0&uiState=670b4060cde83810b20eba9e
So, to my understanding, planetary gear box with 33 outer teeth and 9 sun teeth gives ((33+9)/9)= 4.667:1 reduction. I have defined various mates, but for the purpose of this question I think PC1-Ground, Sun-Ground, and PC2-PC1Pinion are the important bits.
Every time the pinion rotates 360 degrees, the first planet carrier should rotate a little less than a quarter of the way around. This is expressed by gear 1, and seems to work okay based on the animation.
Now, the same relationship applies between the second sun/pinion gear and the second planet carrier. What I'm not quite clear on is how to express that. I could define the revolute of the second carrier relative to the ground, but: 1. I don't have a convenient mate connector and 2. it feels like I should be able to make it work the way I'm doing it.
I'm hoping someone can help me understand where my wires got crossed here. Is there a sensible way to define a "gear 3" given the mates I have set up? If not, how would you mate up this set of parts to get life-like animation?
