How do I add buttons to a UI window like the ones in Routing Curve?
joshtargo
joshtargo Member Posts: 693 EDU
I tried to look at the code, but it links to something that I cant seem to access.
  • GregBrown
    edited October 2024 Answer ✓
    I'll send you one example, and clean it up to share for the rest of the forum… But for now:
    In the predicate for the feature you can create a button type like:
        annotation { "Name" : "My Button" }
        isButton(definition.doSomething);
    Also you need to include a new parameter in your editing logic function, so the function definition looks something like this:
    export function myEditLogic(context is Context, id is Id, oldDefinition is map, definition is map, isCreating is boolean, specifiedParameters is map, hiddenQueries is Query, clickedButton is string) returns map
    //do stuff
        if (clickedButton == "doSomething")
            definition.count = oldDefinition.count + 1;
            return anotherFunctionPerhaps(context, id, definition);
    return definition;
    When you "do stuff" you'll need to check for clickedButton (remember it will be a string) then… do something!
  • GregBrown
    //do stuff
    return definition;
  • joshtargo
    Thank you, this can be a solution for a few different UI needs...
    Now if only my real work would slow down enough for me to just sit and code for a while
  • christopher_dziuba
    christopher_dziuba Member Posts: 124 ✭✭✭
    YEEEHAAAW thanks for this legend!
