After extruding / removing, slicer adds extra wall
luiz_intiniluiz_intini Member Posts: 2
Hello everyone! I designed a 18650 battery holder, but I decided to remove part of the wall to save time and filament. However, when I export that part to STL, Cura slicer adds an extra wall for some reason, exactly at the bottom of the semicircled part. I tried every seeting in Cura 5.7.1, to no avail.
I normally don't use Prusa Slicer (and not very familiar with it) but this time I tried. It looks better in Prusa Slicer 2.8.1.
Anyone here had the same issue? Thank you!
https://cad.onshape.com/documents/9efb5f35921263f10d918943/w/fa792a19edf38493c78b27fd/e/4d25f285d44f1803153a5f32?renderMode=0&uiState=671020272d54b71662e62121
In Cura 5.7.1:
In Prusa 2.8.1:
  • jelte_steur_infojelte_steur_info Member Posts: 650 PRO
    ooh i see, you have a Cura problem. I was looking into the onshape model and figured Cura and Prusa are slicing it just fine, but it seems there's a bug in Cura that causes a step in the rib widening it at a certain point.
    That's very weird. I'm not sure this is the proper place to ask that question though, since the issue is not Onshape related. can you find a 3D printing/Cura forum to post this?
  • S1monS1mon Member Posts: 4,035 PRO
    Does it behave differently if you use STEP instead of STL? Bambu Studio (based on the same code) can handle STEP. This avoids certain tessellation artifacts.
