If you would like to contact our Community Manager personally, feel free to  send a private message or an email.
How to select overlapping objects?
 thorsten_w
                    Member Posts: 2 ✭
thorsten_w
                    Member Posts: 2 ✭
                                  in Drawings
                    I'm having a rectangle where one side is overlapped completely by another line.
My idea is to use the center point restraint to align the rectangle symetrically.
But I'm unable to select the line of (red) rectangle, that is overlapped by the other (green) line.
How can I select overlapping objects?
(In Fusion I would make a long click with left mouse that would bring a menu to selecz overlapping objects)
Select Other is your friend.
I just re-learned this one - hover cursor over line in question, and hit the "~" key, select proper item from list. Matt's right, this is the hot key for "select other"
nothing else to do with your left hand but tap ` (to the left of #1) while hover over object. right click select other gets it done too but i like efficiency 😉
