Loft 2 surfaces with inner loops
microsoft_pp
Member Posts: 6 ✭
in Drawings
I am trying to loft 2 surfaces together to create a solid with a tapered hole, but I get the error "Cannot use faces or regions with inner loops as profiles." I'm still fairly new at this, and help would be appreciated.
Doesn't seem like I can open your link. But you will probably have to do the hole as a separate feature
You can only loft single profile regions - for example, you can not loft a sketch that contains a circle profile inside a rectangle profile. You could edit the circle profile into construction geometry - that way you meet the requirements of a single profile sketch (the rectangle), and then, later you can project the construction geometry to a new sketch for use as a loft profile. I would recommend the "shell" command if your design calls for constant thickness - otherwise a 2nd loft to cut the inner contour is required .
Not sure what the surface fills are about. The solid loft works fine when you add the holes after.
https://cad.onshape.com/documents/c735f911656197548a135a03/w/f0b97f029af9835d24cd6326/e/3a85931eab7ae18560ef7da1
Solved, Thank you.
I don't want the body to be tapered, just the internal hole, which I managed to do, but thank you.
oop, this should work
https://cad.onshape.com/documents/3bae974cb63095d1ec905a5c/w/dfc08c39a2df85ec40cc3610/e/8049ba5aba3313f53a8ec729
