API get request: Get all Variables over all configurations
dsteinegger
dsteinegger Member Posts: 5 PRO
Hello i'm Daniel,
I want to use the API of Onsahpe to get all the variables of all configurations in a Part Studio. Actually, i was already able to do this with the following REST Api endpoints.
Step 1: First catch all the configurations in the partstudio
/elements/d/{did}/{wvm}/{wvmid}/e/{eid}/configuration
https://cad.onshape.com/glassworks/explorer#/Element/getConfiguration
Step 2: Create a for loop in python over all configuration and call the following API endpoint
/variables/d/{did}/{wv}/{wvid}/e/{eid}/variables
https://cad.onshape.com/glassworks/explorer#/Variables/getVariables
So far so good, but each call takes a wile and if you have some configurations the program runtime is too long. The second API endpoint does have the parameter "configuration" and the note next to it mentions that it is possible to request multiple configurations if you separate it with a semicolon. But I tried the following formats and I only get the values of the first configuration. Does someone know how to use this API correctly?
List_YMg2l8wT1PqIXY=Copy_of_TX018_012;Copy_of_TX018_018
List_YMg2l8wT1PqIXY=Copy_of_TX018_012;List_YMg2l8wT1PqIXY=Copy_of_TX018_018
The api can be used and tested via the following link:
Thanks for your help,
regards
Daniel
