Setting UIHint parameters from feature edit function
Hi,
Is there a way to apply UIHints from code - for example make a field read only within the feature edit function if certain other criterion are met?
Thank you.
No, you cannot set UIHints dynamically.
But…there is a work around with editing logic.
Make two identical fields, one that is read only another that is not read only.Make another field that has UIHint.Always_hidden, is a boolean, and controls the visibility of the other two fields.
When the read-only condition is met, set that field with editing logic so that the editable field is hidden and the read only is visible.
Example:
https://cad.onshape.com/documents/8477b927bcadbb9f95b06c09/w/7544e4a05c45a8f6578681b0/e/852cedb2769a0877d1e4dafeexport function EditingLogicFunction(context is Context, id is Id, olddefinition is map, definition is map, isEditing is boolean) returns map { // condition for visibility definition.isVisible = definition.myLengthControl > 50*millimeter; // Update the value definition.myLengthReadOnly = definition.myLength; return definition; } annotation { "Feature Type Name" : "My Feature", "Feature Type Description" : "", "Editing Logic Function":"EditingLogicFunction" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Controls other field readonly" } isLength(definition.myLengthControl, LENGTH_BOUNDS); annotation { "Name" : "control Visiblity", "UIHint" : UIHint.ALWAYS_HIDDEN } definition.isVisible is boolean; if (definition.isVisible) { annotation { "Name" : "My field" } isLength(definition.myLength, LENGTH_BOUNDS); } if (!definition.isVisible) { annotation { "Name" : "My field", "UIHint" : UIHint.READ_ONLY } isLength(definition.myLengthReadOnly, LENGTH_BOUNDS); } } { // Define the function's action });www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications0
Example:
Experts in Onshape Automation - Custom Features and Integrated Applications0 -
Thank you for answering and taking the time to generate an example, much appreciated.
